I predict a Riot
| posted on 17/4/13 at 08:20 PM |
Exhaust part help please
I've tried all the normal places and I can't find one - do they even exist?
I need a 2" inside diameter 45degree stainless steel exhaust piece.
It needs to be a split end style so that I can clamp each end so that the joint is easy to separate if I need to remove the exhaust, which would be
impossible if welded.
Any help much appreciated.
Thanks Adrian
[Edited on 17-4-13 by I predict a Riot]
"Honesty is a very expensive gift. Do not expect it from cheap people ". Warren Buffet on Expectation
snapper
| posted on 17/4/13 at 08:41 PM |
Rally Design, Burtons, Demon Tweeks, eBay
If they don't do split ends cut with 1mm disc in an angle grinder
[Edited on 17/4/13 by snapper]
I eat to survive
I drink to forget
I predict a Riot
| posted on 17/4/13 at 08:56 PM |
Tried all of them.
Burton's do one but it only has a slip joint on one end.
rdodger
| posted on 17/4/13 at 08:59 PM |
If you contact an exhaust place that sells stainless bits I'm sure they could flare both ends of a bend no problem. Failing that exhaust
expanders are reasonably cheap to buy off ebay.
| posted on 17/4/13 at 09:48 PM |
quote: Originally posted by I predict a Riot
Tried all of them.
If its to fit over 2" OD pipe all you need to do is cut the slo ts---- hack saw fitted with 2 blades so it cuts a wider slit or thin
cutting blade in an angry grinder.
There is an ebay seller who has all sorts of exhaust bits and will make specials.
If you want to take it back off use stainless T bolt clamps not U bolt clamps.
[Edited on 17/4/13 by britishtrident]
Madinventions
| posted on 17/4/13 at 11:23 PM |
It's probably not a stock item but give OJZ Engineering a call - 01777 248877.
OJZ website
They manufacture all sorts of exhaust bits and will make up pretty much anything if you tell them what you want. Did a great job on my oddball list
of requirements!
View my band website:
http://www.shadowlight.org.uk
Volvorsport
| posted on 17/4/13 at 11:59 PM |
and if you can draw it - im actually making some 2 inch exhaust parts up at work at the minute.....
www.dbsmotorsport.co.uk
getting dirty under a bus
I predict a Riot
| posted on 19/4/13 at 08:14 PM |
Thanks every one for your advice and offers of help.
I have found a local engineering company who can weld it up for me which was not my preferred option but I want the car back on the road in plenty of
time for Stoneleigh.
Regards Adrian
