ady8077
posted on 1/2/05 at 06:15 PM |
Is petrol conductive?
Hi
Just bought an intank fuel pump off ebay, but the connections are bare crimps. Is something missing or is petrol non-conductive?
Adrian
posted on 1/2/05 at 06:46 PM |
AFAIK, petrol is a non polar hydrocarbon, hence i suspect that it is unlikely it will conduct (ie, it will probably have a massive specific
resistance).
flak monkey
posted on 1/2/05 at 08:15 PM |
resistance).
Petrol doesnt conduct. AFAIK but not because its non polar, its because there are no free ions. Some polar liquids will conduct if you put a high
enough voltage across them as you may be able to break the dipole, thus creating ions (water is a good example). Water only conducts as it is
relatively easy to split the hyrogen from the oxygen. Petrol is just a mix of straight and benzine ring hydro carbons with no poles or ions.
Of course i could be totaly wrong
Sera
http://www.motosera.com
krlthms
posted on 1/2/05 at 08:32 PM |
resistance).
Pure water has a resistivity of 18.2 mega Ohm per cm, so not very conductive;m if you try to pass a current through it you get electrolysis.
KT
posted on 1/2/05 at 08:40 PM |
pretty much what i said flak monkey, you are of course right that being non polar makes no difference i was thinking of solvents for some reasons,
back in my chemistry days
I love speed :-P
posted on 1/2/05 at 08:53 PM |
i dont mean 2 sound stupid (so y say it i hear u say) but even if it isnt conductive but when it runs low what if u get a spark ie somthing goes
wrong? big bang?
[Edited on 1/2/2005 by I love speed :-P]
Don't Steal
The Government doesn’t like the competition
I love speed :-P
posted on 1/2/05 at 08:58 PM |
i no that
Don't Steal
ady8077
posted on 1/2/05 at 10:40 PM |
Thanks guys
I was just worring as petrol and sparks dont mix
I'll leave the guy good feedback now
Adrian
posted on 1/2/05 at 11:16 PM |
You don't jhave to worry too much as the petrol actually goes through the motor itself, i.e. around the armature, commutator and brushes! This
is how the motor is cooled.
Of course poor connections causing sparks on the outside of the pump (but inside the tank) is a recipe for a large explosion.
Rob Lane
posted on 2/2/05 at 12:43 PM |
Only if the air/petrol ratio is correct.
There are different air/item ratios for different items to cause explosions, otherwise it's a controlled burn.
i.e. natural gas/air mix for instance in boilers and fires. Let gas build up to a specific mixture and bang ! Some boilers get close to that when
ignition is slow, hence boom from cabinet.
posted on 2/2/05 at 12:49 PM |
Normally the air space in a petrol tank has too rich a fuel air mixture to be a explosive hazard --- leave the fuel cap off and it would be a
different matter
craig1410
posted on 3/2/05 at 12:50 PM |
I fitted a new in-tank fuel pump to my Rover 800 Vitesse a few years ago and it has crimp type connections inside the tank which bridge the pump body
with the mounting plate. I remember thinking the same thing at the time but the connectors were all nice gold plated ones and were in very good
condition so I didn't worry and just fitted the new pump.
I'd say as long as you use good quality gold or silver plated connectors and have them fitting nice and tight then all should be well. Also
might be worth taking steps to ensure that the wires inside the tank can't vibrate and fatigue.
HTH,
Craig.
