Author: Subject: Denso alternator again...sorry
Batman
posted on 30/3/05 at 07:34 PM Reply With Quote
Hello all, sorry to bring this one up again but I've got about 90% of the way though my MK Indy build using advice that I've got from this site ( ta ) but i'm stuck with my alternator. It's a nippondenso job off the diahatsu shelf at my local breakers, it's got a stud terminal 'B' which is connected to battery, and 3 spade terminals marked F, N & E arranged in a Tee shape ( F & N being the 'legs of the Tee) I attached the blue wire from warning light to F and this lights up ok, but then stays on when engine is running, what does N & E need to be connected to ? or should I just get a newer (old) one with just 2 spades ? ( as previous threads ) thanks for any advice. Have tried probing the other contacts (ooeeer) and apart from buring my hand on the manifold not much happened..
Mix
posted on 31/3/05 at 06:55 AM Reply With Quote
Hi
F is the rotor or field connection
E is the earth
N is the central point
This info comes from the Hella catalogue.
I'm no auto electrician so can't advise exactly where to connect but I'm sure somebody else will chip in.
Mick
kaymar
posted on 31/3/05 at 09:38 PM Reply With Quote
SEE RE[PLY ON VINTAGE BUILDERS POST REGARDS MARTIN P/S IF YOU HAVE AN EARLY JAP ALTERNATOR THEY REQUIRE EXTERNAL REGULATORS AS THEY PUMP OUT 18/20V
