kaymar
posted on 8/4/05 at 10:44 PM |
w/bone bushes
hi please can point me to a supplier of bushes i need 25mm o/d bushes for my wishbones not worried if metalastic or poly or nylon or
blxx"y wood !!! sorry just seems that i am getting it all wrong at present, p/s roughly what ditance/space is there from the front of
chassis to the nose cone, as i have just made radiator mounts to mount micra rad and without a nosecone i not sure if the rad is extending to far
forward at the bottom. "if this makes sense" martin
JamJah
posted on 8/4/05 at 10:57 PM |
Been lots of post about this lately. do a search with bushes over the last month. Youll get several threads with 4 or 5 suppliers on each.
Mix
posted on 9/4/05 at 07:22 AM |
There are some pics of a micra rad and nosecone in my photo archive, also one of the way I mounted it.
If at all possible I would hang fire on the mounts until you have your nosecone as even the Micra rad can be a bit of a squeeze depending on which
nosecone you have.
The photos show an older version MK nosecone.
Mick
clbarclay
posted on 9/4/05 at 09:32 PM |
Is the 25mm OD dimension critical?
Do you already have the wishbones/tubes that the bushes fit in?
GaryM
posted on 10/4/05 at 07:52 AM |
I think you'll find the Lolocost Nylon bushes have an OD of 25mm.
