pathfinder
posted on 11/8/05 at 08:46 PM |
Another trip to the scrappy!
I’m off to the scrappy again this Saturday and hope to get hold of steering column, front uprights and possibly a steering rack. The old boy in the
yard was keen to help when I went to remove the diff last weekend, he mentioned that the early sierras had a different steering lock arrangement that
may be desirable and that he had one kicking about, is this true? I have also been offered some 2wd Cosworth front callipers do they bolt straight
onto sierra uprights? Are all 2wd uprights the same?
Cheers chaps
pathfinder
posted on 11/8/05 at 08:51 PM |
Iv just found the answer to the Cosworth question so I’m sacking that idea off! Are there any other standard ford braking components that can be used
as an upgrade?
posted on 11/8/05 at 09:15 PM |
xr4x4s (and some others) had 260mm discs rather than the normal 240. These usually need a 14" wheel to clear them though.
My lil car has standard cortina brakes and it stops faster than i need it to stop! Some say that having vented discs is not desirable due to the extra
weight, and also not getting up to temperature (too much air flow etc). Good pads are recommended. I often hear greenstuff and mintex pads mentioned,
though i have used neither dont need them yet myself!
NS Dev
posted on 12/8/05 at 07:10 AM |
Joel's quite right, std sierra brakes will be MORE than enough stopping a lightweight 7.
The Mintex pads are 1144 compound. You can get them for std sierra calipers from places lie Rally Design (www.rallydesign.co.uk) and they work from
stone cold and never seem to fade, they are outstanding.
SixedUp
posted on 12/8/05 at 07:34 AM |
I upgraded to Greenstuff pads on vented Golf GTi rotors, and there was a noticeable improvement in both "bite" and pedal feel, but
especially in fade resistance.
However, I'd say that there's no point going mad with upgrades, as traction is already the limiting factor for me - I can lock the front
wheels on a good dry road at will
If you're looking at doing more trackdays then maybe drilled/grooved rotors would be worthwhile to further improve the fade-resistance, but
they'll be more expensive, and I've not had any direct experience of them.
Richard
Rob Lane
posted on 12/8/05 at 07:48 AM |
Early Sierra used a true key ignition barrel compared to the security key of later versions.
With the security key versions once the barrel is slightly worn, a whole lot of other keys will fit it !!
posted on 12/8/05 at 07:32 PM |
true that, i noticed a while ago that any of my ford keys would lock any of the doors on my cars! wouldnt open them though
block
posted on 12/8/05 at 08:02 PM |
Ford keys
All ford keys will lock another ford, but obviously it will not unlock it, generally.
