Author: Subject: biuld pics
martthefridgeman
posted on 11/2/06 at 05:34 PM Reply With Quote
biuld pics
new pictures from today in photo archive. body on order for early april.
ned
posted on 11/2/06 at 06:07 PM Reply With Quote
Looks good so far, maybe we should meet up and exchange notes, you are slightly further ahead than me, but by the time you've received and fitted the infamous avon bodywork, we'll probably be about the same
Where did you get the small alternator and bracket, is it the sbd one? I have an alternator but need a bracket like you have but can't bring myself to pay the £50odd that sbd want just for the little ally bracket!
Another question, how have you plumbed your oil cooler in? Any pics of the way you've done the take off plate, or are you using a sandwich plate? Is the filter in standard location or have you moved it for clearance?
cheers,
Ned.
[Edited on 11/2/06 by ned]
beware, I've got yellow skin
donut
posted on 11/2/06 at 06:19 PM Reply With Quote
lookin good fella!
I like the wheels.
soggy
posted on 11/2/06 at 06:22 PM Reply With Quote
sweet, mines about the same stage.
if at first u dont succeed use a bigger hammer!
martthefridgeman
posted on 11/2/06 at 06:24 PM Reply With Quote
evening ned. i am definately up for a meet. regarding your questions, the oil cooler is via the standard vx sandwich plate and standard oil filter. ground clearance may be a problem for the oil filter, in which case i may try to source a shorter oil filter(possibly a renault 5) or i may fit a sump guard or both.
as for the alternator is a 29 amp item from a kubota stationary engine that came out of a thermoking refrigeration unit. the braket is what came on the engine. i will try to get some more pics of the oil cooler pipework tomorrow. mja
martthefridgeman
posted on 12/2/06 at 02:29 PM Reply With Quote
alternator bracket
ned i was wrong about the alternator bracket,
(senior moment). it did not come with the xe engine it came from an 8 valve astra lump 1.6 or 1.8 at the local scrappy. mja.
Lightning
posted on 17/2/06 at 08:46 PM Reply With Quote
Just 2 things I have noticed
Will your rear brake pipes rub on the wheel?
You have ali paneled the outside of the informous round tube that the body should fit over, This could be a problem area. For warned etc....
martthefridgeman
posted on 17/2/06 at 11:06 PM Reply With Quote
brake pipes changed since original pics taken, i did away with the tiger supplied items and had some made. as below. as for the body and the round tubes i just have to see when the body arrives. mja Rescued attachment P2110669.JPG
Lightning
posted on 18/2/06 at 11:28 PM Reply With Quote
Nice job........and good luck with the body
