Author: Subject: paddles and indicators
ruskino80
posted on 2/7/06 at 10:41 AM Reply With Quote
ideas please on indicator switch solutions when using paddles.lucas self cancelling type considered for dash mount but i suspect you cant turn it on/off quickly(ie. you must let it run)
other idea typical manual lever switch mounted to center of steering wheel.
ideas please and any pics?
MkIndy7
posted on 2/7/06 at 10:53 AM Reply With Quote
If I was doing it again I think i'd look at how a motorbike system works that self cancels after a set time.
The sierra self canceling doesn't seem to work that well as you don't turn the wheel far enough, thats the only reason I can think of that ours deosn't work very well.
And you can't hear the flasher realy clicking and often can't see the indicator light flashing thus leaving them on to the annoyance of many other drivers lol
ruskino80
posted on 2/7/06 at 10:59 AM Reply With Quote
yes i know what you mean with sierra self cancelling-have thought about bike switchgear but mounting is a real issue.
MartinDB
posted on 2/7/06 at 11:49 AM Reply With Quote
I've used Durite switches and can operate the indicators and full/dipped beam without taking my hand off the wheel.
Dash
Dash
Martin.
posted on 2/7/06 at 03:37 PM Reply With Quote
How about small buttons on the steering wheel - to operate indicators with your thumbs. If you wire them up to small piezo buzzers like we have, you'll be able to hear them if you forget to cancel.
Phil
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 2/7/06 at 10:43 PM Reply With Quote
Dash
Dash
Martin.
shouldnt the digidash be in front of the driver?
MartinDB
posted on 3/7/06 at 08:21 AM Reply With Quote
Unfortunately it won't fit between the column and scuttle without obscuring the shift lights. This is as close as I can see it without moving my hand off the wheel and out of the way.
Martin.
RallyHarry
posted on 3/7/06 at 04:49 PM Reply With Quote
How about making your own selfcanceling relay.
Take a optical sensor and put a disc with hole(s) on the steering column.
