New Topic New Reply
Author: Subject: What does your car weigh?
kango
posted on 18/12/06 at 07:10 PM Reply With Quote
What does the average locost (book chassis) & 1600 Kent weigh?
Mine was weighed today.........540Kg
Is that light or heavy?
posted on 18/12/06 at 07:12 PM Reply With Quote
sounds light for a car engined locost. Have you put much effort into keeping the weight down? What device was used to weigh it?
kango
posted on 18/12/06 at 07:19 PM Reply With Quote
Don't know..
Scale with a print out at the local scrap metal merchant.
ch1ll1
posted on 18/12/06 at 07:21 PM Reply With Quote
thats good!
mines 450kg fully wet fire blade
kango
posted on 18/12/06 at 07:24 PM Reply With Quote
I have about 60Hp pushing my car (standard engine)...
What does the Blade give you?
ch1ll1
posted on 18/12/06 at 07:28 PM Reply With Quote
not sure 120ish
posted on 18/12/06 at 07:32 PM Reply With Quote
My standard 1600 Kent locost is 600kg - but I made no particular effort to keep weight down (e.g. steel floor, steel tunnel panels, etc).
Still goes fast (but engine gave roughly 90 bhp on a rolling road)!
[Edited on 18/12/06 by David Jenkins]
Jon Ison
posted on 18/12/06 at 07:34 PM Reply With Quote
440kgs wet.
157 bhp.
132 @ wheels.
should be a bit lighter after winter rebuild, new hubs, shocks, shorter springs.
kango
posted on 18/12/06 at 07:40 PM Reply With Quote
IS THAT A KENT?
stevebubs
posted on 18/12/06 at 07:52 PM Reply With Quote
not a locost, but zetec Fury with carpets, doors. windscreen and full weather gear
620kg according to local weighbridge
Jon Ison
posted on 18/12/06 at 08:05 PM Reply With Quote
Originally posted by kango
IS THAT A KENT?
sorry, I should read the post properly before posting, its a BEC.
erwe
posted on 18/12/06 at 08:20 PM Reply With Quote
420 kg with fuel tank filled and 178 bhp...
RichieW
posted on 18/12/06 at 08:56 PM Reply With Quote
Kango,
Dont put your engine down. The Haynes manual for the mark 2 Escort has the 1600 Kent Crossflow pushing out 84 HP.
Thats a lot more than your supposed 60Hp or is it just that your engine's shagged?
Kissy
posted on 18/12/06 at 09:12 PM Reply With Quote
420kg wet - no heater, no full screen, with older CBR1000F (about 20kg heavier than a modern bike engine). Whilst not a Locost in the truest sense I did not spend any significant amounts to achieve this.
ed_crouch
posted on 18/12/06 at 09:40 PM Reply With Quote
You can get 160 out of a crossflow.
Takes a lot of money though. I know of one that does about 160BHP, but its tricker than Paul Daniels and Debbie McGee put together.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
posted on 18/12/06 at 10:48 PM Reply With Quote
Our ZX-12R engined Indy weighs in at approximately 490Kgs wet with 152 bhp at the wheels.
That's a little over 300 bhp/tonne...
Simon
posted on 18/12/06 at 10:54 PM Reply With Quote
Deimos (Rover V8) weighs about 700kgs - soon to have twin turbos and 300(ish) bhp or 420 ish bhp tonne
Simon
Stu16v
posted on 18/12/06 at 10:58 PM Reply With Quote
200bhp is possible out of a normally aspirated xflow. Just write the (large) cheque out to 'Mass'...
Chaz
posted on 19/12/06 at 10:17 AM Reply With Quote
Zetec 1800 weighs 570kg fully wet. Mk Indy.
bimbleuk
posted on 19/12/06 at 10:28 AM Reply With Quote
As a comparison and as I've actually weighed it
Striker IRS chassis. 535kg wet and half a tank of fuel (no driver).
Just a fly screen fitted. 20V 4AGE, type 9 GBX, Sierra diff, drum disc drive shafts.
phoenix70
posted on 19/12/06 at 12:13 PM Reply With Quote
My INDY with a 2L Pinto weighs in at 620kg
jimgiblett
posted on 19/12/06 at 01:42 PM Reply With Quote
420kg, 155bhp (133rwhp). Ruined by 90kg of ballast behind the steering wheel.
317bhp/tonne
- Jim
kango
posted on 20/12/06 at 03:33 AM Reply With Quote
Was only concerned because I had a number of 500 Kg in my mind (don't know where I saw it) but I used 2mm walled tubing and thought that would have been the reason I missed the 500Kg.
I also have no screen and all internal pannels are ali.
wilkingj
posted on 24/12/06 at 11:18 AM Reply With Quote
317bhp/tonne
- Jim
OOhh... Mines BIGGER than YOURS!!
V8 Viento, about 750-800Kgs.
Spoilt by 124Kg of Ballast behind the Steering Wheel, and 127Kgs in the Passenger Seat (this is 6ft 5" of Son)
Rolling roaded at 179Bhp... (But still need some more)
Now you know why I NEED a V8
Mind you, it still goes well considering the payload.
[Edited on 24/12/2006 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
locostv8
posted on 25/12/06 at 09:07 PM Reply With Quote
[QUOTE=Locostdude] [QUOTE=calvin] This is the car that was protested.
[/QUOTE]
Interesting discussion. What this photo does not show is the 330 pound steel plate that is bolted to the bottom of this car to bring the weight up to 1775 pounds. That's 350 pounds over D mod minimum weight.
Also, the transmission was broken so the whole event was run in high gear, starts and all. The protested car was second in D Mod, and second in E mod, with no changes except driver.
This car has been in develoment for 35 years.
One more thing. The motor is stock except for the after market cams.
Del Long[/QUOTE]
This car weighed over 1850 lb to be allowed to run in two autox classes. Light weight is only part of the equation. The ability to get the power to the ground and driving skill are equaly if not more important. Overweight/broken/stock eng and still took 2nd in both classes.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
New Topic New Reply
