Author: Subject: Would this work?
macnab
posted on 19/1/07 at 03:03 PM Reply With Quote
Would this work?
just my worthless 0.000001p's worth
Of course there’s a middy discussion going on just now. But I thought you could do this – fit a standard fwd engine and gearbox fitted 90 degs from norm, one drive output locked on the gearbox. The other going via an angled propshaft to a diff (say a sierra item). His this been done before?
And yes I’m waiting on the computer again, can you tell?
iank
posted on 19/1/07 at 03:08 PM Reply With Quote
Yes the sporting trials guys do this all the time.
It gives you a super low ratio for climbing 45 degree muddy banks...
Probably not what you are looking for unfortunately.
Edit: bugger came second again (must tell the missus )
[Edited on 19/1/07 by iank]
Anonymous
stevec
posted on 19/1/07 at 03:09 PM Reply With Quote
I think one problem will be having two lots of final reduction, 1 in the front wheel drive box and 1 in the rear diff,
Steve.
[Edited on 19/1/07 by stevec]
macnab
hmm I was not sure of the ratio at the wheels. Pity
though I thought the output shaft from the diff would double it's rpm when the other is locked...
Going back to lego car days there!
[Edited on 19/1/07 by macnab]
goodall
posted on 19/1/07 at 03:35 PM Reply With Quote
also since the diff planet-gears arnt designed to constantly turn at high rpm they would were out eventually
macnab
posted on 19/1/07 at 03:43 PM Reply With Quote
That’s a good point since the planetary gears are meant to only turn a small amount when going round corners and certainly not at double the rpm that the diff was suppose to run. So really this is a rubbish idea, oh no not another...sigh
Aboardman
posted on 19/1/07 at 03:53 PM Reply With Quote
why not just just use a vw passet engine which is inline and is front wheel drive?
macnab
posted on 19/1/07 at 03:56 PM Reply With Quote
Is it?!
didn't know that. I was pondering about the new mk single seater. Don't really fancy a bike engine, as the traffic in Aberdeen is awful
goodall
posted on 19/1/07 at 04:12 PM Reply With Quote
you could weld the diff solid and remove the other driveshaft stub and plug the hole into the diff housing that means that u dont have to bolt one side solid to the gearbox and you dont have the problem of the planet gears turning since theyd be welded and then theres the problem of ratio, that could be over come by flipping the diff welding a sprocket of the smallest diameter to the smaller side and replacing the pinion gear with a sprocket of the largest diameter that will fit and then driving it by a chain
goodall
posted on 19/1/07 at 04:14 PM Reply With Quote
personally i might do this myself but wont weld the diff i will instead go for awd for better handling on poor surfaces like the local roads
[Edited on 19/1/07 by goodall]
mark chandler
posted on 19/1/07 at 05:16 PM Reply With Quote
Seen a few 4x4 racers with this, drive shafts to each axle, only problem is max speed around 75 which is just not enough !
novacaine
posted on 19/1/07 at 08:15 PM Reply With Quote
so are pretty much all of the 2wd audi's
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
macnab
posted on 19/1/07 at 08:45 PM Reply With Quote
new it was a great idea!! he he
goodall
posted on 19/1/07 at 08:55 PM Reply With Quote
only major set back of this idea to get around finding a rwd gearbox is you still have to find a diff, that said you can buy freelander diffs new so maybe it is a way forward
