sgraber
| posted on 7/7/03 at 08:55 PM |
Updated my website - Watts Link
Got lots done this weekend even though it was a bloody 113 degrees farenheit. Even so, I managed to finish up a few projects. Check it out if you
like. Go to my Diary page and then follow the links off the entry dated 7/7/03.
Comments (positive and negative) welcome.
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
kb58
| posted on 8/7/03 at 01:12 AM |
Yeah, with the heat, guess what happens when a person decides to weld while not wearing a shirt. Instant sunburn. I did that to myself this (warm)
weekend.
TheGecko
| posted on 8/7/03 at 02:39 AM |
Steve,
Looks good, if a bit beefy. Although I suppose the difference between beefy and fragile is only a pound or three so why torture yourself. I've
been think about some sort of saddle clamp to put a Watts link centre pivot bolt in double shear. Don't know whether it's more work than
is justified. Time will tell. In the interim I'm watching your and Alan's sites with mucho interest
Kurt,
I NEVER, NEVER weld without covering exposed skin since I sunburnt a perfect silhouette of the hole in my shirt onto my belly when I did my original
welding course. I don't care how hot it is, it's overalls, gauntlets and auto-dark helmet for me when welding. This is a pain because
here, even today in deepest winter, midday temps are about 20-25C (68-77F). In summer, our peak is around 35C (95F) and as much as 85-90% humidity.
Not good overalls weather
Obligatory progres report - I have some negotiating to do with an engine importer and, assuming that goes the way I want ( ie less $$) I will pick up
a blacktop 20-valve Corolla front cut next week. Actual cut and weld of chassis will be very soon after that. Only 390 days to my goal of rolling
before my 40th birthday - yikes!!!
Best regards all,
Dominic
Brisbane, Australia
sgraber
posted on 8/7/03 at 04:12 AM |
Better beefy than broken, Problem is I seem to be applying that philosophy to the entire build and I think it's getting heavy. Should still be
under 1,400 Lbs finished tho.
Go Dominic! - About damn time! hehehe
I often weld without a shirt on. As long as the metal has been degreased, I don't find it to be a problem (molten metal goes trhough clothing
anyways). I kinda enjoy the instant tan effect. Saves money not having to visit the tanning salon...
Steve Graber
Alan B
| posted on 8/7/03 at 11:47 PM |
Steve, there aren't tanning salons in Pheonix really...are there???
Watts linkage looks good...beefiness about right for a road application IMO.
Question for you (or anyone)...will the sideways force on the rear tyres (tires) be greater on a middy than a standard locost?......I guess it must
because of higher weight at the rear??
If so I'd say your Watts linkage needs to be fairly substantial. (which it is)
