Author: Subject: MGF
Fred W B
posted on 21/11/07 at 11:24 AM Reply With Quote
MGF
A mate of mine turned up at my house over the weekend in an MGF his son had just bought. As I’ve never driven a rear engined car before, I took up the offer of a drive and found it very pleasant, at least at the gentle cruising you can do in an urban environment.
Why am I telling you this?.....
My mates son actually IS a hairdresser!
Fred W B
[Edited on 21/11/07 by Fred W B]
andyharding
posted on 21/11/07 at 11:36 AM Reply With Quote
I've had 2. Much prefer front engine rear drive. The MGF is evil in the wet and once the back starts to go all you can do is hold tight and hope for the best.
posted on 21/11/07 at 11:39 AM Reply With Quote
It is a well engineered and superbly thought out car; if you are ever caught in a shower whilst driving, all you need to do to dry your hair is to lean back
DarrenW
posted on 21/11/07 at 12:29 PM Reply With Quote
Is the Sat Nav in a MGF sponsored by Toni & Guy??????
brynhamlet
posted on 21/11/07 at 12:40 PM Reply With Quote
My wife had one.
It is certainly not well engineered. Two head gaskets, two radiators, rust on the offside wing, new clutch and when we sold it it had only about 60,000 miles on the clock
Great fun to drive I admit, but I did have it swap ends in the wet.
Never ever will by a rover product again
mcerd1
posted on 21/11/07 at 12:56 PM Reply With Quote
a car that sarted out as 2 metro front ends nailed together
it didn't even get real springs untill the TF
[Edited on 21/11/07 by mcerd1]
Danozeman
posted on 21/11/07 at 01:36 PM Reply With Quote
One of our friends turned up at ours with a nice top spec blue one. He said he's always wanted one so he bought one. He isnt a hairdresser but he is gay. He lievs in scotland and drove it down here (suffolk) for the weekend, it started tapping and never made it back. No oil in it and it went bang.
I have driven a TF with the auto gearbox. Strange thing to drive.
[Edited on 21/11/07 by Danozeman]
Dan
posted on 21/11/07 at 03:02 PM Reply With Quote
Rear wheel alignment is very critical on these cars, not help by the fact a lot had bent rear tie rods due to transporter drivers caused by either lazy car transporter drivers tying them down by the suspension or incorrect jacking. There was also a mod on one of the rear suspension bushes.
[Edited on 21/11/07 by britishtrident]
posted on 21/11/07 at 03:04 PM Reply With Quote
Originally posted by britishtrident
Originally posted by brynhamlet
My wife had one.
Very important not to automatically blame any water loss on these engines on the head gasket, always always always pressure test the complete cooling system when cold to find where the water loss is really from.
Unless the engine has already been been cooked nine times out of ten water loss is caused by inlet manifold or radiator leaks.
The remaining one time out of ten head gasket failure is caused by over revving the engine from a cold start before the thermostat opens, Rover introduced two modifications to eliminate this problem,
A clutch problem at low mileage is rare unless caused by driver misuse.
The MGF & MGTF the clutch is either 200mm dia in the 1600 or 215mm in the 1.8.
The 1.8 clutch is the same as that used in the Rover 800 Turbo.
speedyxjs
posted on 21/11/07 at 03:15 PM Reply With Quote
Same with my jag and that has FR setup. Loads of fun though
Marcus
posted on 21/11/07 at 04:03 PM Reply With Quote
Bought the wife a TF in September - within a week we had a clutch problem. The car had covered 37000 miles.
Turned out the release arm had siezed in the bellhousing - you could just disengage the clutch - then it slipped as if badly worn. We were due to go on hols in it 4 days later and ended up changing the clutch and release arm on my drive after work. Hours of fun and swearing!!
Still we got it done and drove it to the South of France for 2 weeks.
The car handles really well, is reasonably swift, looks good in black, and I really enjoyed driving it for 3000 miles.
BTW, I'm not gay or 'owt!!
Marcus
Because kits are for girls!!
big_wasa
posted on 21/11/07 at 06:40 PM Reply With Quote
Mate of mine had one and I loved it
and will have one one day.
locoR1
posted on 21/11/07 at 07:29 PM Reply With Quote
Got my wife one in march this year, one week later I'm putting a headgasket on it and its only done 32000 miles!
Nice car to drive with the roof down but dose your head in at anything over 60mph with the roof up! she loves it though so if shes happy.
Dave.....
Check out my CB500T Cafe Racer build diary
posted on 22/11/07 at 08:25 AM Reply With Quote
A known problem on any car with the PG1 gearbox, usually caused by pressure washs/steam cleaning the engine bay.
It is generally very easy to fix without removing the gearbox --- all thats required is a bottle of coke and a 2 lb hammer. Afterwards lube the pivot shaft generously.
posted on 22/11/07 at 08:33 AM Reply With Quote
Dave.....
Always Pressure test before you strip it down !
I have seen a very large number of K16 engines with misdiagnosed coolant loss.
One RAC man diagnosed a head gasket on a 75 Turbo when the problem was a blown up turbo unit.
Usual suspects are the inlet manifold gasket at the cam belt end of the engine, the rad or the cheap hose clips Rover were using.
If the head gasket is blown pressure test it after you build it back up and bleed the system. You must find why it lost coolant in the first place.
Always use a new inlet manifold gasket.
If it hasn't got the external PVR thermostat fit one.
[Edited on 22/11/07 by britishtrident]
