motivation cars
posted on 10/1/08 at 02:24 PM |
oil temp on zetec
ok without sounding daft where can i put an oil temp transducer on a 1600 zetec
joe
martin1973
posted on 10/1/08 at 02:44 PM |
i dont know if its the same on all zetecs but on the silver top i have theres a second tapping in the block just back from the oil pressure on
normally pluged with a torx head plug
martin
posted on 10/1/08 at 02:45 PM |
If you look around the head there are two or three taper threads with blanking plugs in them.
On my 1.8 there is one at the front just above the inlet and one behind the coil pack. There's another one somewhere I can't recall at the
moment.
![](/galpreviews/P7040009.JPG) ![Zetec V ZZR1100](/gallery/P7040009.JPG) Zetec V ZZR1100
You can see the plug through the hole in the bracket?
[Edited on 10/1/08 by coozer]
Ian D
posted on 10/1/08 at 08:36 PM |
I would check the thread of the plug and the sensor you plan to buy. You might find the plug is metric and the sensor NPT.
Hope this helps.
Iam
posted on 13/1/08 at 07:38 PM |
They are 1/8th NPT on mine. I attached my Racetech pressure gauge straight in without any adapters.
mark-wiring
posted on 13/1/08 at 10:48 PM |
Joe
If i were you mate i would not worry about it.
The zetec is designed to run higher oil temps than you would expect
and put an oil cooler in at your own peril thats the best way to clog up the tappetts and get the valves sticking open
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
