thepest
posted on 18/1/08 at 07:52 PM |
Escort Diffs
Does anyone know if the brake drum assembly (slave cylinders,shoes,adjusters etc) could be fitted from an Escort Mk2 diff to that of a Mk1. They Look
similar exept the Mk1 does not have automatic shoes adjuster. Could I a set from a Mk2 diff on a Mk1 diff?
gazza285
posted on 18/1/08 at 09:22 PM |
You certainly can, the axle casings are identical.
short track 123
posted on 18/1/08 at 10:25 PM |
Why bother with drums ?
Just put a set of disc's on it.
Regards
Jason
TGR-ECOSSE
posted on 18/1/08 at 10:29 PM |
Regards
Jason
You wouldn't happen to know who sells such a thing as discs to fit an escort back
axle
thepest
posted on 19/1/08 at 08:06 AM |
I like the disc brake option, but from the ebay link what are they referring to when they say:
"You will need to turn down the hub part of the 1/2 shaft to a diameter of 136.5mm"
I have a mk2 rear diff so I was wondering if I could do the conversion without extra cost.
mic
posted on 19/1/08 at 08:40 AM |
check out HERE
www.retromods.co.uk
posted on 19/1/08 at 10:12 AM |
The diff doesn't enter into it, the axle casing will fit brakes from most other Fords including Mk 1, 2, 3 Escorts, Fiestas, Sierras etc. but
you will need the complete assembly including back plates and handbrake cables to make them work. They used the same bolt spacing on the back plates
which makes the job easier for anyone wanting bigger or smaller rear drum setups, 8" or 9". The bolt holes are not evenly spaced so they
will only fit in one location.
short track 123
posted on 14/2/08 at 09:40 PM |
Yep there mine....
I can now supply disks that fit the standard 1/2 shaft. So no need to turn down any thing just buy and fit.
As far as i know there is no other disk kit that you can
just fit with no mods to any part of the axle.
Please excuse but I do pay to be a registered trader
Jason
www.shorttrack.co.uk
