Arnie
posted on 9/3/08 at 08:37 PM |
Tin Top - Clio
Looking for some help. My daughters Clio (2001) has developed an intermittant fault. It starts first time okay. However a few seconds after starting
the ABS and Power steering lights start to flicker and you loose the power steering (power steering is electrical). Also loose the indicators and
radio. However drive it for a short distance and it goes back to normal only for the same thing to happen agin. Have checked as far as possible for
any loose connections but to no avail. Has anyone come across this type of fault before. Any help would be much appreciated.
Regards,
Arnie.
dan__wright
posted on 9/3/08 at 08:44 PM |
i would stick a multimatare on and monitor the voltage
FREE THE ROADSTER ONE…!!
rayward
posted on 9/3/08 at 08:45 PM |
may be worth asking on
Here
Ray
Guinness
posted on 9/3/08 at 08:58 PM |
I'm no expert in Renualt electrics, it sounds to me like a dodgy ignition switch or steering lock.
I used to have a massive bunch of keys that I used to carry round with me all the time. Of course they then hung off the steering lock while I drove.
After a while the lock didn't stay in the same place, and the ignition switch used to either cut out or change with bumps etc.
Might be worth a shot?
Mike
Arnie
posted on 10/3/08 at 06:29 AM |
Thanks for the info. Will try the Renault site as well.
Regards,
Arnie
posted on 10/3/08 at 02:53 PM |
If not switch it sounds like either a bad earth or a battery/charging system problem.
Check the voltage across the battery with DMM -
(1) Before starting
(2) During cranking
(3) During inital running
(4) When problem disappears.
Arnie
posted on 13/3/08 at 06:13 PM |
Tin Top - Clio
Thanks for all the help. Turned out to be a faulty alternator that was overcharging/high voltage. Alternator changed and all now okay. Thanks.
Arnie.
posted on 13/3/08 at 06:56 PM |
Arnie.
Alternator failure of this kind is very often cause by bad (loose) connections at the alternator -- if this is case often the problem goes away for
a few months after a new alternator is fitted then re-appears.
[Edited on 13/3/08 by britishtrident]
Arnie
posted on 14/3/08 at 06:50 AM |
Thanks for the update. Will check the connections to make sure.
Regards,
Arnie
