New Topic New Reply
Author: Subject: Rear brake flexi hose?
Mark G
posted on 28/4/08 at 05:27 PM Reply With Quote
Hi all,
I tried to fit my rear brake lines on the weekend and for a few reasons I couldn't. The only thing that I'm stuck on is how to fit the flexi hose for the rear wheel cylinders.
It looks as though it wont fit between the cylinder and the upright?
Any suggestions, I was thinking I may need new cylinders.
stevec
posted on 28/4/08 at 05:35 PM Reply With Quote
I did mine like this, There are other ways as well.
JohnN
posted on 28/4/08 at 05:36 PM Reply With Quote
Isn't there even room for a Banjo fitting? even when its tightened up??
Maybe have to connect the banjo first before fitting the drum assemby
Mark G
posted on 28/4/08 at 05:46 PM Reply With Quote
Both very good ideas
I may try and make up a small copper hose like to top one.
Thanks guys.
stevec
posted on 28/4/08 at 06:06 PM Reply With Quote
Make sure the pipe is new stuff, as the bends are tight and the pipe goes hard if you play with it too much, "Oooh er missus"
afj
posted on 28/4/08 at 07:00 PM Reply With Quote
you get some short lenths of copper brake pipe for drums with the kit
Guinness
posted on 28/4/08 at 07:07 PM Reply With Quote
Ditto Steve's install and you get the small lengths of copper as part of the brake line kit from MK.
HTH
Mike
paulmw
posted on 29/4/08 at 08:38 AM Reply With Quote
Word of Warning
I fitted the copper pipe the same as stevec and it failed the SVA. The man said that it wasnt flexible enough. You need to replace the copper for flexi or get a 600mm new flexi hose
Paul
SyKaTurbo
posted on 29/4/08 at 11:59 AM Reply With Quote
Did you bracket it? I wouldnt have thought it needs to flex running between two fixed points on the same part of the chassis. How did you overcome the problem?
Guinness
posted on 29/4/08 at 12:21 PM Reply With Quote
Originally posted by paulmw
Word of Warning
Paul
The drum brake is in a fixed position relative to the hub carrier, so provided the bracket is attached to the hub carrier securely then what is the problem. That short length of pipe should be a fixed install, with the flexi doing the flexing?
Unless I am mis-understanding you?
I passed SVA with exactly the same set up as Steve.
Mike
paulmw
posted on 29/4/08 at 12:35 PM Reply With Quote
Sorry your probably correct as I have rear discs so the caliper does move slightly. The simple fix would be for MK to supply a 600mm flexi
Perhaps my tester was being ultra efficient and he just didnt like copper to flexi to copper
Paul
martyn_16v
posted on 29/4/08 at 07:39 PM Reply With Quote
I'm guessing that he just doesn't like rigid connections to moving parts.
Mark G
posted on 29/4/08 at 10:33 PM Reply With Quote
it would appear that i'm missing two small pipes then? Think I'll be calling MK tommorow.
New Topic New Reply
