Author: Subject: RS Turbo
injected
posted on 20/5/08 at 03:43 PM Reply With Quote
RS Turbo
Gents,
Heres one to kick about.
I am currently running a MFI CVH unit ex early XR3i running Bosch K Jetronic.
I have now aquired an RS Turbo unit from a series 1 .
Having a quick squint it looks like I can get all the gubbins in but do not really want to go to hassle of fitting the EFI chips and sensors required for the KE Jetronic.
Anyone know if K Jetronic will run with turbo and what mods would be required.
I have induction sorted. Exhaust will work It's just fuel, sparks and air to make it go.
And yes I know it would be easier with EFI but it's a toy so why do it the easy way.
mark-wiring
posted on 20/5/08 at 07:18 PM Reply With Quote
S1 RST is MFI not EFI so a quick change of metering head and splice in the management for a S1 and your there.
Obviously you need to lower compression etc etc
[Edited on 20/5/08 by mark-wiring]
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
injected
posted on 20/5/08 at 07:50 PM Reply With Quote
Sorry didnt make clear.
Have complete new engine from RST therefore CR etc no issues.
XR3i is full mechanical with fuel pressure control no ecu at all just pump relay.
To splice in KE jetronic system would have to fit new ecu to have somthing to splice to.
I Have a butchered RST meter head and airflow sensor which can swop out with XR components to make good. Just using the base with hose connector instead of airbox/filter assembly.
From what I have seen so far the only additional control I would need is boost control which is done by pulse signal from the original ecu
Or am I missing somthing.?
mark-wiring
posted on 20/5/08 at 08:52 PM Reply With Quote
been a while but i think there is a vac pipe that also goes to the rst ecu
Have to recommend
injected
posted on 22/5/08 at 09:31 AM Reply With Quote
Had a look dragged out the haynes and it seems there is no way of doing it without loom mod.
Have now decided to wait for winter and do the Job properly stand by for megasquirt questions by the bucket load.
injected
posted on 22/5/08 at 09:32 AM Reply With Quote
Thanks anyway
mark-wiring
posted on 22/5/08 at 01:47 PM Reply With Quote
LOL Yeh ill be asking those questions soon too once the bodywork on my mk3 escort is done and i put the engine etc back in it
Have to recommend
martyn_16v
posted on 23/5/08 at 08:37 AM Reply With Quote
Ignition. If you leave it running the same advance as the normally aspirated engine it's likely to go pop quickly.
