Hadders
posted on 12/6/08 at 04:55 PM |
5VY R1 engine mounts - Source of 12.9 cap head bolts?
I'm trying to find some high strength bolts for the engine mounts. I need M10 fine x 80mm and M10 fine x 150mm. Everywhere seems to only offer
these as hex head 8.8 or stainless soft as cheese versions. Anyone know where i can get some 12.9 grade?
Also can you buy 12.9 grade studding? Currently using bog standard 8.8 for the other mounts but have already bent one.
TIA
jimgiblett
posted on 12/6/08 at 05:09 PM |
I got similar but in M8 from PTS
http://www.pts-uk.com/
- Jim
Hadders
posted on 12/6/08 at 05:15 PM |
Thanks Chris. I just bought standard studding so 4.8 would explain why it bent so easily. I'll go lookign for some 8.8.
Cheers Jim. I'll check out their site.
Ben
Johneturbo
posted on 12/6/08 at 05:32 PM |
Namrick are woth a try
http://www.namrick.co.uk/
mad-butcher
posted on 12/6/08 at 05:39 PM |
do a search on ebay shops for wvsfasteners I got mine from them but I'm certain 12.9 isn't needed, if in doubt ask malc at yorkshire
engines always found him very helpfull
tony
[Edited on 12/6/08 by mad-butcher]
Hadders
posted on 12/6/08 at 06:07 PM |
Namrick were my first call but they couldn't help.
stuart_g
posted on 14/6/08 at 09:09 PM |
12.9 is standard supply at my local fastnings shop for cap head bolts, 8.8 for hex bolts. Also I am pretty sure the mounts are not fine thread in the
top mounts. I'm sure I have some left over I can measure the length if you want. Instead of using studding for the lower mounts I was advised to
tap the engine to M12 and use bolts.
