gy351100
posted on 27/6/08 at 06:51 PM |
overheating problem HELP
Hi all
A friend of mine has been having a problem with over heating on his Nissan Primera 2.0i 16v (p12)
Symptoms are:
Every 2 to 3 weeks the temp gauge suddenly goes up and down quite quickly and the fan kicks in
The engine is deninitely over heating but the gauge seems very unstable
There is no evidence of any leaks but the water level needs to be topped slightly
I suggested possibly a faulty temp sensor
Any other idears anyone
Keith
eznfrank
posted on 27/6/08 at 07:11 PM |
What's the oil and level like?
matt.c
posted on 27/6/08 at 07:14 PM |
Head gasket? Have you looked at the colour of the engine oil?
mr henderson
posted on 27/6/08 at 08:53 PM |
Thermostat not opening properly? Is the radiator good and hot when the engine is overheating?
John
gy351100
posted on 27/6/08 at 10:24 PM |
overheating problem
John
The thermostat not opening properly doesn't explain why the gauge goes up and down
tks
posted on 27/6/08 at 10:53 PM |
one thing bad doesn't mean another thing cant be right...
so maybe he has a short / fault temp sensor (which many times is mounted n the thermostat)
but the overheating could be a 2nd problem.
maybe it overheated the sensor!! and it went mad...
posted on 28/6/08 at 08:23 AM |
Slow coolant leak causing loss of coolant circulation -------- to track it down requires a pressure test on the system with the engine cold.
This is the only way to trace slow leaks.
Modern engines run so hot leaks just flash off into steam which contrary to popular belief is completely invisible.
Of course the simpler way is just to tip in 1/4 of a container of K-Seal (NB not Radweld or Barrs-Leaks which should not be put near any
modern engine)
[Edited on 28/6/08 by britishtrident]
posted on 28/6/08 at 08:46 AM |
I should add Japanese cars use a different glycol based antifreeze-coolant from European and American manufacturers.
The Japanese red antifreeze while still ethylene glycol based has a different additive blend, while the two types will mix using european antifreeze
in Japanese cooling system will often result in leakage.
