Hey guys,
I'm currently planning to make my own chassis from round steel... Much like the rocket, warner R4 etc etc but there are a couple of things
I'm not sure of...
Where is the best place to buy the steel I need and how much I'm I likely to pay???
I'm going to get a tube bender but what sort of presure do I need... Would a 12 ton press do?
And lastly what's the best way to notch the tubes, will I need a tube notched or is there a little known locost way???
All help is greatly received :-)
Phil
Make sure you buy a tube bender NOT a pipe bender, my tube bender has a 10 ton jack in it, bends 1-1/4 OD 1/8 wall OK.
I use a holesaw, hacksaw, grinder, and files, whatever suits really.
HTH
Neil
Google Tubemitre for a way to notch the tubes, it may be worth a search on here?
you seen this? wish I'd though of it!
linky
If your looking to do a atom/warner t4/MEV clone, you need a three ring roller for the long gentle shaped chassis tubes, something like this
http://www.stakesys.co.uk/product/pro_tools_roll_bender/
Theres a pipe notcher in the Frost catalogue, can't find it on the webby though.
May be worth the investment if your doing lots of joins/angles etc.
I cannot see where the £1250 is in that tool. You could fabricate a properly laser cut one for £250.
Hey guys,
Thanks for all the info so far... I was going for a 'locost' Exo car but maybe that's not going to be possible with the tools needed
What sort of bends to sand rails have??? Could you build one of those with just a bender?
Originally posted by pocket rocket
Hey guys,
Thanks for all the info so far... I was going for a 'locost' Exo car but maybe that's not going to be possible with the tools needed :-/
