13'' wheels and brakes!
needforspeed - 11/10/10 at 09:30 PM
currently running 15s with 285 wilwoods and sierra 2wd rears i can change the fronts/adjust the brackets but what about the rears? will they fit under 13's?
RJK350 - 11/10/10 at 09:49 PM
I'm running 13" Team Dynamics on my MK Indy. Wilwoods on the front and Sierra calipers on the back. The only problem was the hand brake springs rubbing the inside of the wheels. I had some special springs made with 1 coil less to miss the inside of the wheel.
I have sets left as I had to order a minimum quantity from the spring manufacture. Please U2U if you are intrested.
Rob
matt_gsxr - 11/10/10 at 10:10 PM
No they probably won't fit.
If you have wheels other than Team Dynamics then Sierra disks don't really fit under them.
You can do a hub modification (machine down to 134mm o.d.) and use Mk3 Fiesta front (non-ventilated) disks. These move the disk surface further inboard. Mk3 escort front disks bring it further inboard still, but are a bit heavier.
Not sure whether Sierra Cosworth disks are larger than standard Sierra, but even standard sierra are a problem.
Matt
mark chandler - 11/10/10 at 10:26 PM
I,ve got proper minilights, had to grind a bit of the rear caliper away to fit, also a set of lookalike minilights, these have much more clearance.
You need to try a wheel before buying... some do, some do not !
Gergely - 12/10/10 at 08:32 AM
I run 13" Compomotive CXR's on Sierra rear calipers, and have done exactly as Rob, had springs made with one coil less. This now clears the wheel and the stick-on weights.
No problems with the Raceleda front calipers.
Gergely
hobbsy - 12/10/10 at 08:36 AM
I don't think TD's are the only ones that can clear Sierra brakes.
I've tried several wheels and once the spring is one coil less they should fit.
This includes CXR's, Caterham 6 spokes, MB mag R500 wheels etc.
matt_gsxr - 12/10/10 at 01:06 PM
All the cheap ones then.
They don't fit under 4-spoke Compomotive Revolutions, which are the best wheels in the world.
Matt
beaver34 - 12/10/10 at 07:05 PM
what size disks are people running on the rear? i have cossie calipers and i can run 13" wheels
Fredrik Jönsson - 20/3/11 at 09:10 PM
I have front disks from a Sierra with drums at the rear. Will 13" Team Dynamics fit? What ET should I use?
daniel mason - 20/3/11 at 09:31 PM
i got the modded spring and run 13" r500 wheels. fit perfectly!
speed8 - 20/3/11 at 10:20 PM
Gergely
Me too, CXR's with Sierra rears and Wilwood fronts
