Dannys not having much luck with engines this season, 2nd one this year, this one went in a big way at his last race at Oulton, con rod through the
side of the block on his Dry sumped 1340 busa.
http://www.youtube.com/watch?v=klDLSDJhlGs
Some close racing there. Whats the funny hand wave when changing gears all about?!? lol
It sounded a bit rattly at 07.17
and that noise would drive me nuts after 10 mins
Ouch...! That did sound expensive! Did he find a cause?
Yes I thought I could here a rattle from early on in the video, and the problem is they can't find the cause, as said its the second time this year on a dry sump set up he's blown the engine, at £3500 each its getting expensive, so they need to get to the bottom of it, last couple of years he's had a billet swing sump set up and not had any major problems, he's gone for dry sump as a belt and braces job, but for what ever reason its not working
glad its not just me, i thought it sounded a bit "big endy" from the start but wasnt sure what a healthy one sounded like to compare with.
I feel for him+his wallet. Looks like another CEC convert.
There is something that sounds like a gear change but isn't just before it blows. Not sure what that is but very odd, like it's jumped a gear. Wonder if lost oil pressure at that point.
Gutted for you Danny............
If the engines out of a crash damaged bike it makes it harder to find the reason, was the bike running on its side etc? Plenty of engines get sold
as being good runners, when they've not turned a stroke since the bike was damaged.
In an ideal and expensive world he'd have a full strip down and rebuild carried out, if it still goes bang then he'll have a good engine to
start looking at without the question marks over its original condition.
I can only imagine how annoying and expensive it all gets.
That Engine was "chappin" its brains out on the run up the pit lane from the off, and to be honest if whoever was driving/supporting in the
pits didn't realize that, that engine was already sick, then I have no sympathy for the expense, that car should have been in the workshop having
major investigative surgery on its engine.
not having its nuts thrashed off round a track.
I agree with Hector, big end rattle is definitely there from the off and gets less severe as revs bring up oil pressure and starts to float the crank.
Rattle creeps back through the low speed stuff and there is a definate change in engine note right before the yellow 7 gets overtaken, probably the
last of the shell going. Problem is what is causing the failures, lack of pressure, lack of flow, bent cranks, tight shells the list goes on. One
thought is what parts of the install got replaced after last blow up, I have lost count of how many good engines have been taken out by debris from
previous blow ups, we don't even try and clean oil coolers any more.
Regards to all
Thought it was just me that could hear that sounding a bit unhappy at low revs from the word go. At 3500 quid a time it must be seriously painful to not be able to spot what seems to be an unhealthy sounding engine! I feel for him!
That engine sound horrible from the word go, doesn't it ?
Originally posted by Andy B
One thought is what parts of the install got replaced after last blow up, I have lost count of how many good engines have been taken out by debris from previous blow ups, we don't even try and clean oil coolers any more.
I have utmost sympathy for wrecked engines... The hassle is a right pain, even without the expense.
Just been to MK today, the engine that blew is not one thats been in a bike thats been dropped or raced before the engine was a totally new so had not been fitted to anything. Its was dry sumped to improve its lubrication etc. There appears to have been a problem with oil starvation on one of the rods leading to a meltdown of the rod I will try and upload a picture later. The noise that can be heard from the start is something to do with the airbox. Danny is on the lookout for another engine at the minute they are a bit scarce I understand. He is due to race in a couple of weeks at Anglessy
