Had last week off work and managed to make some good progress on my Indy.
Still a few things to do like trim, mirrors, front/side indicators, aero screen, cat, bonnet catches etc... but generally pleased with my progress.
Im pre IVA so any comments, critisism or praise appreciated
MK3
MK6
MK5
MK7
MK8
MK9
Unsure what to do air filter wise?
MK1
MK10
real nice build there...
just a couple of things..
do the front arches come down far enough at the back of the wheel,
relays under dash on passenger side will need covering
not sure on radius edge on speedo/rev counter
will toggle switch on tunnel be ok
some people have failed IVA with grooved gear knobs I believe
really does look good thou
[Edited on 7/9/12 by gavin174]
Put big O rings in the grooves of the gear knob then it should be fine. I have a toggle switch on the tunnel aswell for the indicators. All i did
was put switch guards either side so the sphere couldn't touch it.
10 out of 10 for that dash.. Looks very nice. Best I have seen..
great detail mate
Looks great.
I am not sure about the handbrake lever if it is being left uncovered.
With reference to the switch guards for indicator switch on tunnel.
I do not know how much the mini ones cost, but I have purchased stainless ones from the
US for $6.99 each. Excellent service.
www.periheliondesign.com.
Just make sure you select the 5mm diameter ones for IVA....
HTH
Len.
Mine are from perihelion too. I bought a few from CBS then found that the perihelion design ones are exactly the same and a load cheaper.
Davegtst that is one stunning dash!! What edging have you used around your clocks and gear indicator? I can't even see the join!
Ben
Why thank you kind sir. It's u trim from cbs, I tried other u trim from ebay but it didn't bend round the corners aswell. If you look closely the join is at the very bottom center.
Davegtst: seriously lovely piece of work. I just wonder how many hours? I'm not even remotely saying they're wasted, more saying
craftmanship has its price.
What's your background? Did you have extra skills to bring to this great piece of work?
Thanks again although I can't see what the fuss is about. To be honest I don't think the dash took that long to make. The carbon dash is from mk alli did was cut holes in it and bolt and glue things on.
I feel a monty python sketch coming on.
When I got my fury all they had were the really simple slab sided dash boards.
I don't know if they've improved on them at all.
M
It's a healtech gipro. It's only held in place by the U trim being a very tight fit.
Sorry bizarro looks like your thread has been a bit hijacked.
One of the best dashes you'll ever see. Beautiful design, and that includes the tunnel cover.
I would be seriously concerned about driving with front arches like that, spray off the roads and flicking stones at me, but I haven't read the
the new IVA regs to be honest
tony
