sierra Mc Pheersons used by mk's....
eddie - 1/6/03 at 12:09 PM
anyone got any pix i can see or dimensions of the front sierra uprights,
got some old mcpheersons cut off below the spring mount and the hub carrier / disk setup
my plan is to turn the mc pheerson leg end bottoms down, insert a turned up peice in the top of the tube with a thread to suit a ball joint sat on top, mig the lot round in a seam weld for a custom suspension upright
i just need to see how much of the leg i need poking out above the top face of the carrier.
i'm told mk do this so any pix to copy would help loads
locodude - 1/6/03 at 02:37 PM
You were told wrong. The whole of the leg is removed and an adaptor sleeve (cup) is bolted in it's place. The ball joint is then fastened to this adaptor. I believe what you're talking about is the way that Fisher/Sylva/SSC do it.
kingr - 2/6/03 at 10:36 AM
I believe viper has an extremely useful diagram of the sierra upright in his photo section.
Kingr
eddie - 4/6/03 at 07:56 PM
cheers chaps, you've given me new ideas, shoulnd be hard to turn up an adaptor.....
bob - 4/6/03 at 09:24 PM
Last pic in my archive shows overhead view
