velocity top wishbone ball joint
tj4ord - 25/5/09 at 08:21 PM
Just a quickie can anyone tell me what thread size the lock nut is for the top wishbone ball joint? ie the bit that goes into the wishbone.
cheers
tomgregory2000 - 25/5/09 at 08:25 PM
Do you need some?
Tommy
g.gilo - 25/5/09 at 08:28 PM
m18 x 1.5mm
graham
rusty nuts - 25/5/09 at 08:29 PM
18x 1.5mm IIRC
tj4ord - 25/5/09 at 08:31 PM
cheers all and yes i need 4
tomgregory2000 - 25/5/09 at 08:47 PM
ive got 2 you can have, they got a bit of grease on them as i replaced my top ball joints coz the rubber had split so they are spare i can send them in the post for you.
U2U me your address if you want them.
Tommy
tj4ord - 25/5/09 at 09:03 PM
U2U sent cheers
