Fuel line clips
SPY290 - 28/3/04 at 12:50 PM
I am running 2 fuel lines down tunnel.
one is flow, the other is return.
I also have got to run a 3rd for charcoal canister, about the same size as break line. (used for fuel fumes).
The problem I have is how to clip them down the tunnel, P-clips is one option, but with limited space to fix them.
Does anyone do fuel line clips with a single fixing (like on production cars) that will take the 3 pipes?
If so can anyone post a few links.
Kieth - 28/3/04 at 07:08 PM
Try demon tweaks. They do a two in alloy and arnt cheap but not sure if they do a three way.
Hope this is of some help
SPY290 - 28/3/04 at 08:20 PM
Thanks Kieth, but dont think they will do.
Need something like the plastic clips on a production car.
Spent the afternon surfing the web for companies that do clips, but they only do P clips.
Bugger!
wicket - 28/3/04 at 09:29 PM
Jetpress do a 3 way that maybe suitable, usually OK for samples
http://www.jetpress.co.uk/search.asp?start=40&offset=10&SearchType=group&strHyperlink=1
SPY290 - 29/3/04 at 08:23 PM
Cheers Wicket
