Hi,
Does anyone know the width of the luego supplied windscreen, along the bottom?
Mine is 900mm measured horizontally at the bottom
I will measure mine for you in the next couple of days.
Its the same as the robin hood zero FYI
Hi mine measures 930mm from edge to edge this includes the sides/uprights.
This was using a piece of string and following the contour of the scuttle.
As Dan has said the Robin hood/Great british sports cars screen for the zero is the same size.
