Hi, Where is the best place to get zetec engine mounts from??
For RWD?? Make them.
Have a look at kitpartsdirect.com - GBS (Robin Hood) they do some
As said make them (or get them made), simple enough, just measure accurately and a good welder with some steel stock can make them up in minutes.
If you're a bit unsure, make up a couple of dummies out of wood (couple or square bits of ply (5ml or so thick) and some broom handle/thick dowel
(or similar) cut to the correct angle. Get your engine in the correct position, drop in your rubber mounts, tape 1 ply square over the mounting holes
in the block, the other over the rubber mount (drill a hole) then carefully cut the dowel to length, glue the whole lot together, jobs a good un. Take
that to your fabricator and get it made.
Now I wish I'd done that to start with!
[Edited on 21/1/10 by norfolkluego]
Mine came from GTS for not alot. Its up to you whether or not you decide to get from them.
I think mac#1 and fisher do them.
here a help full site if you make them
http://www.toyne.org.uk/docs-mount.html
As said above,make them. i made mine,it took all of about 40 minutes to do and cost nothing.
