I have a problem with the rear wheels on the car at the moment stcking out too far.. Wheel suppliers I talk to say 7J x 15 offset 35 will fit a
locost... However I have this size compomotive MO on the rear and they stick out too far from the arch with a 205 tyre.. They are actually in line
with the outer edge but where the arch is shaped at the back the tyre will rub on the return edge of the arch.. So long story to get to the
question....
Has anyone fitted 7J *15 offset 35 on the back of a Luego Velocity or have you fitted 6J's?
thanks
Dave B
Had exactly the same problem, the easiest thing to do is make spacers out of plywood (or similar) to push the arches out a bit, several threads on here about it.
Thanks....
I'll have a search...
Dave B
