does any1 have a clue if a mx5 rollbar will fit and be ok for iva?
how wide is it at its widest point sure u need about 44 inch at widest point do u have a roadster manual should have mesurments in it
you don't need a roll bar for iva
I used one for my 442, but had to make it narrower. I cut out the required section, placed a tube inside about 2' long, plug welded and seam
welded it in place and job's a good 'n
. So for a standard sevenesque-type chassis I would say it will be waaaay too wide (the 442 is
4" wider than a standard Locost).
HTH
thanks guys will have a measure up just like the look of the mx5 rollbar. didnt no you didnt have to have one tho!!
