Hi
I have a velocity running a 1.6 zetec on 40 DCOE's and it's all good BUT...
I also have a supercharger from a mini, so has anyone used a mini supercharger on a zetec?? I was thinking bike throttle bodies, ECU, intercooler and
dump valve etc.
Any ideas
Thanks Adam
Ive only heard of one in a 7 and that was Lhd. But what a sound
http://youtu.be/Ghjc_I1wQ-g
I just dont see how you can route the steering linkage on a Rhd car.
Originally posted by big_wasa
Ive only heard of one in a 7 and that was Lhd. But what a soundhttp://youtu.be/Ghjc_I1wQ-g
Now that's what I am talkin about!!
I think I could get it in over the exhaust, I think I will mount it and see how it looks
I recall someone doing a supercharged crossflow in PPC magazine 6 months back. That was in an older westfield. Check the back issues.
Lee
I have seen post on here someone using a m45 charger on a zetec,
I am just looking in to throttle bodies, bypass valves, dump valves, ECUs, pulley sizes, injectors ect.
Any help would be good
Im using one on a renault 21 engine.
How have you piped it up.
Have you used a dump valve?
What's to stop me using the DCOE carbs I already have and just rejetting.?
Personally, with a super-charger, I would put the Exhaust straight out over the top of the side rail and with a heat shield arranged like I did in my
normally aspirated car, then mount the super-charger under the exhaust.
I would think one of the best guru's on this sort of fit (ok he did a Duratec, rather than a Zetec, but the principles would be the same) would
be Flak Monkey. Have a look at his build thread in the engines section (IIRC).
Also of interest to talk to would be Madteg (based in kettering), He built a VERY quick 2.0 Zetec Turbo and knows what their strengths and
weekness's are.
