I have now got to the stage of my build that means I can't go much further with the engine without sorting of what sort of ignition I will
use.
I have spent some time researching different types of Dizzy etc and lots of different people have had different experiences. Some people have had
good succuess with megajolt systems. I just don't know which route to go down. The cost is a problem as always.
Could you good people please advise me what your thoughts are.
I bought a Edis 8 off USA ebay and two coil packs off a member here. A trigger wheel off triggerwheels.com at Stoneliegh.
My intention is to get rid of the crap points system and have a nice reliable fat spark.
All this running of my spare MS.
You can buy the whole lot from Trigger Wheels, prices on their website Linky
I appreciate that it's not the most high-tech solution but mine's on the original Lucas electronic dizzy from the Range Rover it came from
and has been perfectly reliable.........
Simon
I didnt have a working / worlable Dizzy so got a Mallory Aftermarket one off Fleabay.
I 'spose it was right place, right price at the right time. Dont get many opportunities like that.
Contactless is really nice, and good, but dont discount a good old dizzy. The rover ones are known for the odd problem, although you can get an
ignition amp from RPI engineering. Chris Crane there is very knowlegable. Howver, thats not that cheap either!
Think it thru before parting wid yer cash!
When I went from carbs to injection I thought I'd go the whole hog and switch to EDIS as well. You still need the bottom end of the dizzy in the engine to run the oil pump. My MS tells the EDIS how to adjust the timing, but MJ would do that as well if you stick to carbs.
Thanks for the responses guys. I think I have got the gist of the situation now and I am swerving towards the MJ option. Purely because I don't have a dizzy to start with and I think in the long run MJ seems to be more predictable. Just got to get this sorted and I am almost ready to try and start the rebuilt V8 for the first time. Must admit I am nervous as hell about that.
