Hiya,
Me again, man of thousand questions!
This is my accelerator pedal, mount and bolt that came with my Viento. Putting the big bolt though the pedal and mount just seems a bit to rough. I
was thinking something like a nylon bush or maybe a sort of crush tube setup might give a better 'feel' to the pedal. Any suggestions or am
I making mountings out of very small mole hills.
Bit quiet in the Luego section recently. I guess we aren't getting very many 'newcomers' are we.
[Edited on 11/10/11 by Irony]
Tried a bit of grease? Maybe the powder coat needs scraping off around the pivot? The bolt is totally OTT so there are other options. Best keep it
simple and with little resistance you don't want the accelerator sticking (don't ask How I know, in a 600kg you don't have much time to
react!!)..
Dan
Yeah the bolt is huge for the job. You could probably swing the entire car from it.
no neeed for a bush or anything. It works well as it is and feel fine when driving. my only issue is needing to fit a pedal stop as the travel is more
than I need. I'll get round to this once I snap the throttle cable.
Paul
may have fitted a washer each side to stop any sideways play. No need to have the bolt tight its a nylock.
NO problem with mine, all as std.
Just a little grease, and a light spring at the carb end.
My Luego locost has a large clevis pin secured with a split pin, been fine for years
Just bolt - not too tight - been good for 4 years now...
Very quiet on here - all busy modding are we?...
Personally just busy
Thanks guys. Standard setup it is then!!
