Hi All
Been a while since I've managed to get onto the forum, but I was thinking of getting a megajolt bolted onto my v6 cosworth lump,
has anyone got any wise words as to weather this would be a good or bad idea??
Thanking you in advance...
Ollie
Why not go for megasquirt and control the EFI as well? The EDIS 6 and coil packs would still be needed for either, so youll be more likely to get additional power from controlling the fuel as well.
you will need an edis 6 and they are rare
Luckily i have the Edis 6 already,, i have a ford baby Ecu in there at the moment, but im having al sorts of issues with it.
Ollie
I would defiantly look at a m'squirt instead... just disable the fueling part and run it Ing only
Lots more features to it even then than a MJ
Thanks for your advice,, dropped Phil a line at extraEFI, He should be able to point me to the correct M-Squirt..
Ollie,
I have the BABY as well - I'm getting strange fuelling issues (still) - stuttering at higher revs in higher gears?...
What are you experiencing?
Cheers, Neil.
Neil
My problems have come from the initial wire up of the engine to the Baby. i'm afraid i have been in the dark a little since reaching this part
of the build. (a handy ford mechanic would go down a treat) but many people have recommended going for the after market ecu, i think it may solve
some problems (and many hours pulling my hair out).
Are you still running the fore runner to my BOB v6?
ollie
Yep - I'm a BOA - doing OK even with a stutter!...
Chippy (Ray) is in your area I think and he's running the cossie as well - He's a bit of a genuis so might be worth U2U-ing him...
N.
