Does anyone know the correct size tubing for the Luego bushes? I bought the bushes from them a while back and the guy I spoke to did say but I've forgotten.
Sorry to bump this up, but could someone measure the OD of the bush tube on their wishbones? Should be able to work out what guage tubing is required
from that.
I took a bush to the local metal stockists to try and match it to a tube but nothing they stocked was even close (although these are the people that
told me they didn't stock 25mm RHS as it was an unusual size!)
[Edited on 20/9/04 by MikeRJ]
I would have thought a call to Luego would be a bit easier than getting someone here to measure it for you!
HTH,
James
[Edited on 21/9/04 by James]
