veinto brakes
lugo35 - 8/10/04 at 07:41 PM
hi this might sound strange but will drums fit on the veinto hub carriers or is it only discs??? cheers andy
nutter - 19/10/04 at 10:10 PM
erm drum brakes are not going to be good on one of these cars! stick with the disks
ChrisW - 20/10/04 at 09:23 AM
I'm sure they'd go on... but as said, why??
Chris
MikeRJ - 20/10/04 at 03:57 PM
Drums will be more than adequate on the rear surely? They manage to stop a considerably heavier car after all.
lugo35 - 20/10/04 at 06:23 PM
was gonna upgrade at a later date to discs was wondering if the hub supplied is any different for the to???
nutter - 23/10/04 at 08:45 PM
you are proberly more likly to spend more cash on fitting the drums, then fitting all the other stuff for disks later. The veinto is a high performace car, so the disks will be a lot better when you thrash it!
zetec - 23/10/04 at 09:23 PM
Don't get stuck on the idea that discs are needed. I have discs on the rear but drums would be more than up to the task. I sometimes wish I had gone for drums then I could fit 13" wheels!
It's not till the car is built that you find out what you really should have done rather than what you thought was needed.
