Hi can anyone tell me the tyre pressures for my tiger zetec it's running proxys on the road thanks
Start at 23 and have a good drive, then increase the psi to 25, is it better or worse? Then back to 23 to reset your internal gauge, drop psi to 21
and do the same.
It's a very subjective thing, most tyres I use work between 21 and 24 once warm.
Don't know what wheels & tyres you have but Tigers will be quite harsh at 20+ psi. My Supercat runs at 16 - 18 psi on 205 x 50 x 15. When I
first had the car the pressures where at 25 psi and it just crashed from one irregular road surface to the next - even on a motorway!
Michael
I ran my striker 16 /18 psi tyre pressures
I'd start at 22 psi and experiment downwards from there. Unlikely to need more than 22 unless your tiger is unusually heavy. used to run 17psi in my Westy
I run 18PSI on my Avon
