hi, now youre looking at this site.
i was just wondering if i could get a locost that was half irs and half book. im going down the road of de-dion rear.
what im looking for is a 'book' chassis with a diff carrier. front wishbones to be irs, ie to take the sierra front stub axles. the rear suspension to
have the normal trailing arms and panhard rod with the normal damper mounting points. then to have a pair of sierra rear hub carriers as well. the
de-dion axle itself i can get.
just wondering if you can help.
Hi Findlay, we can do what you want no problem. All we need to know is the vertical hole centres of the de-dion tube, and we can modify the chassis to suit. Other wise we can do you a standard book back end with the Sierra front wishbones, and you make the alterations. Give us a call 01487 815643. Regards The Team.
thank you for the prompt reply and help.
i will be calling you today or in the next few days.
cheers
Look forward to hearing from you soon.
