HARROGATE 2005 FANTASTIC SHOW OFFER
Velocity Xt
Build Blaster Harrogate Show Offer
Summer Build Blaster Deluxe Kit Includes
Chassis Fully Bracketed & Welded Floor, Road Roll Bar with 4 point harness bar, Full Wishbone Set front and rear, Hub Carriers Disc or Drum, Polly
Bush Set, Deluxe Ali Internal & External Panel Set, 4 Shocks and Springs, New Downlink, Wiring Loom with fuse box, 8mm Fuel Pipe, Gold Pedal box
for cable clutch, Roll of brake pipe and unions, 3 way and 4 way union with brake switch, Goodridge Hose set Disc or Drum, Wishbone Bolt Kit, Rivet
pack, Top and Bottom ball-joints, Track rod ends, Rack Extensions, Steering Rack and Brackets, Ali Conversion Boss,
Show Price £3243.58 Inc Vat
IF YOU ORDER AT THE HARROGATE SHOW WE WILL GIVE YOU A FULL 8 PIECE RACE GRP TOTALLY FREE!!!!
YES THE GRP IS TOTALLY FREE, SAVING YOU £693.25!!
Powder Coat is an extra £175 Inc VAT
The Sierra-based Velocity Xt is a traditionally styled roadster, which uses as much as possible from the donor car without compromising the blistering
handling or ride. As such, you'll find bespoke double wishbone suspension on each corner utilising the Sierra front stub axles and rear
differential, drive shafts, bearings and all braking components. Engine choice will typically center around the Ford range of 4-cylinder engines
(Pinto, Zetec, etc) while the Xt will also accept the Toyota twin-cam units and Motor bike units. Those looking for larger alternative engines would
be better advised to look at Luego's larger Viento model.
Viento “The Big Brother”
Show Price £3643.58 Inc Vat
YES THE GRP IS TOTALLY FREE, SAVING YOU £891.23!!
The Luego Viento came into being in order to fill Luego's regular enquiries for a larger version of its existing Velocity. Because Luego has
added almost six inches to the width and twelve inches to the length, you won’t struggle to get comfortable in the Viento. The other advantage of the
Viento’s generous girth is the ease with which larger engines can be accommodated, with the Rover V8 now a simple drop-in exercise! Elsewhere, various
customers have fitted Chevrolet 350ci V8 and BMW straight six engines etc! Not surprisingly, the Viento chassis is a beefy spaceframe affair designed
with such power plants in mind, while the suspension follows popular convention, with double wishbones at each corner and a full Sierra-based IRS.
