Taper for front ball joint
Johnmor - 22/1/06 at 10:39 AM
I'm still try to reach the rolling chassis stage and i need to modify the taper on my sierra hubs to take the Maxi ball joint .
Popping to luego is not an option (450miles). Does anyone know where I can get a taper drill of the correct size, or how they dealt with the same problem?
Snuggs - 22/1/06 at 11:06 AM
I had the same problem.
Local engineering firms would do it but would need to construct a jig to hold the hub at the correct angle.
I was quoted £70 for the correct sized taper drill from a number of local suppliers.
In the end I went to Luego (260 mile round trip).
Probably the cheapest option would be to post to Luego and get them to do it.
