I have bought the Gold floor mounted Pedal Box form luego. I am now as the stage of fitting the brake light switch.
What type of brake light switch have other people used or did they just get one form luego?
Also where did they fit it? As I don't know where would be the best place
thanks
matt
Most fit them in the hydraulic lines
brake light switch
Intermotor 51650
£2.75 from motor factors
ok thanks
will have a look and see what i can get hold of then
thanks again
matt
Yep, a hydraulic one is by far the easiest to fit.
