Mounting pedal box
ChrisW - 4/6/03 at 02:10 PM
Just been thinking about the best way to mount my pedal box. Are the bolts which hold the master cylinders on enough or should I be putting some extra bolts through the floor aswell??
Chris
Findlay234 - 4/6/03 at 02:38 PM
I wondered just the same thing after recieving my luego pedal box. looking thro photos sections seems to agree with bolts through the floor.
andyd - 4/6/03 at 05:26 PM
We've put two 10mm bolts through the bulkhead to secure it in place. With the four that clamp the master cylinders as well it seems solid enough. The only danger may be that the bulkhead may flex when stepping on the pedals which may lead us to popping a couple of 8mm's through the floor to keep the front section down. Probably only happen with the brake pedal as that's the one that needs the most force to push. But then you don't use the brakes that much do you?
[Edited on 4/6/2003 by andyd]
