Catalytic convertors
Cubby - 4/3/07 at 04:29 PM
When do i need a cat fitted? is it necessary if engine can meet emissions level without one?
Any one know any good units for a seven?
zxrlocost - 4/3/07 at 04:42 PM
what engine mate need more info
russbost - 4/3/07 at 05:12 PM
Whatever the engine if it is to be subject to CAT emissions test (post Aug '95 build)at SVA or MoT it will need a CAT on it. Whilst technically possible to meet emission criteria without a CAT in practice it's almost impossible.
Cubby - 4/3/07 at 09:33 PM
Yes thanks All. It's a Zetec 2.0ltr 1999 Blacktop . If I need a cat any recommendations ???
Paradoxia0 - 5/3/07 at 10:50 PM
Hi Guys
Now reading this thread I was obviously mis-informed...
I was under the impression that if you were using an old engine (i.e. a donor one) that was pre-catalytic converters then as long as you don't try to register it on a new plate (i.e. a 56, 07 etc) then you didn't need a cat...
If I am totally wrong on that and you do then can anyone offer advice on what cats to use with a rover V8 and polished stainless steel exhausts?
Paul (Notts) - 6/3/07 at 06:25 AM
If its older than 1995/4 ish then you do not need a cat....
so dont panic!!
Paul
[Edited on 6/3/07 by Paul (Notts)]
