Throttle cable
darrens - 15/4/07 at 06:59 PM
Need above, but it needs to be very short, any ideas?
andyharding - 15/4/07 at 07:01 PM
Buy long one and cut it down?
blakep82 - 15/4/07 at 07:01 PM
brake/accelerator cables fron go-karts seem quite useful. i'm pretty sure you could also shorten them more if you had to. look at the ones that zip karts use
darrens - 15/4/07 at 07:05 PM
was contempleting that but then that buggers up the nice crimped end
jollygreengiant - 15/4/07 at 08:20 PM
they are expensive, but, renault/citreon/peugeot throttle cable kits have multiple end fittings, teflon liners & you trim to fit.
nitram38 - 15/4/07 at 08:55 PM
What about a halfords bike brake cable?
DRC INDY 7 - 15/4/07 at 10:42 PM
I got mine from tescos from the bike section £1.98 1.5m in length perfick
caber - 15/4/07 at 10:44 PM
Vehicle Wiring Products do make your own cable parts in their motorcycle section. I have used the size 5 for my handbrake. I lttle blat with the welder can put a useful blob on the end of the cable if you don't fancy soldering nipples on.
Caber
rusty nuts - 16/4/07 at 07:26 PM
Little tip for cutting the bowden cable , use a sharp chisel , lay the cable on a block of metal and give the chisel one sharp tap with a hammer . Cutting with pliers etc often caues the cable to unwind.
