quick question - how much space do I need lo leave from the base of the rear panel to fit the nuber plate light - in other words how far from the
bottom of the panel to the light.
cheers
Paul
About here
Paint 4
Thanks Andy for the helpfull reply.
Paul.
standard (legal) number plate is 111mm, so a bit more than that
hth
Ray
I don't think there is a minium or maximum height - and I'm sure you could mount is so it shines upwards - pretty sure cars had that in the
past but maybe SVA say no?
Before you start drilling the holes, have a look what is on the other side of the panel e.g. petrol tank to see that there is enough room/access for
the bolts and so you don't drill into the tank
You may also want to decide if you are going to fit a number plate surround as well first. That could be fitted first followed by the light. The plate will fit no probs then.
