mudguard brackets
billy - 13/9/03 at 07:24 PM
im fitting a pair of brackets for mudguards on the front of my locost luego,and they seem to be hittting the suspencion mounting brackets and look as tho they are too far away from the tyre when they are bolted up.im using sierrra front uprights with rs turbo discs.the brackets were brought from luego at the kitcar show.anyone had problems with these fitting?????also im concerned about the way they sandwich inbetween the top bolt on the upright,as i have the aluminium converters fitted and they seem to prevcent the bolt from doing up tight on the converter.any help????cheers
tobygee - 13/9/03 at 07:35 PM
i have made a simular brakets and you do have to tighten the bolt realy tight (i also have the luego inserts) the best thing to do is get a mallet and try knocking the top wishbone out! if it doesnt move its ok!!!
billy - 14/9/03 at 04:10 PM
did you find there was enough clearance against the shock mounting bracket,it seems to be touching it.
Luego Sports Cars - 27/9/03 at 01:12 PM
They need bending back slightly.
