Well I'm in the middle of a week of work. So I've been a tinkering in the garage. Program was to be remove engine & gearbox and fit
hydraulic clutch components to gearbox. Refit gearbox, WITH new propshaft. Refit engine. Have a little saunter up & down under own steam for the
first time.
So I pull car back and get out engine hoist. Get engine ready to lift out.
Problem 1. Can't find lifting chains ANYWHERE. Never mind I'll just have to use seatbelt webbing.
Hook up engine & begin lift.
Problem 2. Hoist needs jack oil, can't find my large syringe for jack filling either. Turn house upside down. At 3rd look around I find syringe
in draw where it normally lives and where I've now looked 4 times. (blind numpty).
Anyway I pull engine & gear box and fit hydraulic slave.
Slave cylider mounted
then made a cover plate for the old release arm hole.
Armhole cover plate & hose
While I had the box out I thought I'd check the fit of the propshaft. It fitted like a glove.
Problem 3. How ever I couldn;t turn it because it was fouling on the remote gearchange extension by close on a quarter of an
inch.
So I have had to take the extension off for the time being. I think I would have to remove too much to be able to use it.
So I put the engine back in and today I just have all the little bits to put back on again.
Problem 4 (may be). Whilst sitting here typing this out and up loading pictures, I can't help but think that I can't remember if I tightened
up the bleed hose where it screws into the slave cylinder.
AAAAAARRRGHHHHHHHHH.
I had to have a propshaft made with a smaller front U/J housing, I think its a common problem with the gear stick remote extensions
Steve.
Sounds like a pretty average day's build activity really
It's the little things that try the patience.
is that a type 9? if so where did you get the kit and how much did it cost?
ditch
Problem 2. Hoist needs jack oil, can't find my large syringe for jack filling either. Turn house upside down. At 3rd look around I find syringe in draw where it normally lives and where I've now looked 4 times. (blind numpty
Looking good, Clive - Keep it going mate and you'll have a winter wonder on your hands.
No way you can (easily) get the engine back more? What about cutting out the small cross bar on the top of the tunnel, welding two new ones in front
and behind the gearstick where it then comes out?...
No way you can (easily) get the engine back more? What about cutting out the small cross bar on the top of the tunnel, welding two new ones in front and behind the gearstick where it then comes out?...
Actually looking at the photos, if I undo that plastic cover I might be able to get a spanner and my huge dabs somewhere close to checking that hose
fitting without taking the engine out.
