hi all
can any one help me by mezering the size off there finished viento nose to tail and how wide it is at its wideist section
there are some cheep flatbed trailers comeing up for sale at my locil farm arction/sale that wont take to much modifing to work as a car trailer and
iam going to see if any are the right size for my car but dont no the the specs and its not in the build manual
cheers jim
[Edited on 14/11/07 by repper]
Just got home from work will measure it after tea
Paul
just point out my car has 20mm spacers on the rear wheels so may be 40mm wider across the rear wheel centres than the normal depending on your rear
wheel offset. mine is the recomended leugo viento rear ofset ( cant remember what it is )
[Edited on 14/11/07 by Paul (Notts)]
measurements are approx as the car is in the garage and hard to measure the distance between rear wheel centers - all others are quite accurate.
a = 185 cm
b = 155cm
c = 148 cm
d = 67 cm
f = 344 cm
not sure what happend to e ?
Paul
spot on chears paul ill print your pick off and take it with me
chears again jim
