Can you take a measurement from one side of the chassis, to the other where the drivers side of the schuttle panel meets teh chassis - i am looking to get a carbon effect dash panel and i want to know how wide ill need it.
i will measure it for you
if you have 1 minute??
tks
Well the total with = 107,2cm
and the high needed will be some 33cm
this high is the approx high of the scuttle sow i don't count with going down touching the tunnel etc.
hope it makes sense
Tks
[Edited on 21/11/07 by tks]
cheers mate.
thats what i needed.
to touch the tunnel you need 41cm of height
tks
i was hoping to get this, but it looks like it will be too narrow
http://www.carbonmods.co.uk/showProduct.asp?prodID=110
are you sure that measurement is right - 170.2cm?
the Luegosportscars website says the chassis is 1070mm wide...
hi i have got the exact dash on my luego locost, the scuttle is lower than a velocity. but it has plenty of depth as i trimmed a bit off, as for
width, it just about fits. the "ear" bits just fit snuggly at the bottom of the scuttle. im happy woth the dash and how it fits, i can get
yo some pics if you like.
rob
oeps you are right
its 1072mm
sow it can fit nicely
tks
thanks guys..
can i also say... "gemma.....ummmmmmm" im so glad more people are changing their avitars..... brightens my day...
