A big thanks to Matt at Casarva (07828320086) for doing all of the necessary welding work to get the engine, gearbox and diff in
Pic 1 - Engine from the front
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008041.jpg
Pic 2 - Waiting for Zorst
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008042.jpg
Pic 3 - Engine Front
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008043.jpg
Pic 4 - More Engine from front
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008044.jpg
Pic 5 - Engine from side
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008045.jpg
Pic 6 - Diff Pic 1
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008046.jpg
Pic 7 - Diff Pic 2
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008047.jpg
Pic 8 - Diff Pic 3
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008048.jpg
Pic 9 - Diff Pic 4
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008049.jpg
Pic 10 - Diff Pic 5
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008050.jpg
Pic 11 - This was once a car! What have I done! LOL
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10022008051.jpg
It's all looking good the following bits are sorted:
god these pics are huge
personally I'd have shrunk each down to 400 pixels wide then opened paintbox, made the area the total stacked hight of all the pictures, then
pasted each into that one long picture. But that's just me.
there you go
Looking good. welcome to the world of inserting an S2000 into a luego. Fun innit!
cheers
ricky
Looking good!
I'm currently in the middle (more at the start, really) of a Dax Rush build with the F20C. Some pics
here.
I've also decided to go down the route of using the stock ECU, and have had some helpful input from both the US (Ultralite)and Australian (PRB)
folk, though I've only really started thinking about this part of the build.
Have you found any helpful tips and tricks for using the Honda ECU you can share?
Also, what are you doing for an exhaust manifold? I know they're not the same car, but I'm after ideas
I managed to find a routing for the steering column to just miss the oil filter, and give enough room for changing it. This is using the Dax set-up -
modified Sierra column with a UJ a few inches back up from the trouble spot - just skirts round nicely.
The guys I know that have fitted Honda engines to their cars use the Hondata equipment rather than stock. Apparently it is easy to configure.
http://www.hondata.com/
looking good...
Matt said to me that he was doing some work with an S2000 engine - he also said that you used to have a zetec and throttle bodies? If so, what have
you done with the throttle bodies?
thanks Mr Whippy,
I'm far too lazy to do that
Saigon - sorry mate all sold
PeteS2k - I used the standard ecu as easiet and cheapest option - just had the immobiliser circuit removed. I'll also clear the engine management
light by 'frigging' the system - using my mates MODUS diagnostic system.
Keep bugging me - and I'll document it for you
Chris - Many thanks for ALL of your considerable help and advice! Indeed I need to get my finger out ASAP. It's going in for Zorst this weekend
and driveshafts/prop sorted by the end of the month. Then its wiring it in getting a running car - then sorting the dash etc etc.
M
Originally posted by muzchap
PeteS2k - I used the standard ecu as easiet and cheapest option - just had the immobiliser circuit removed. I'll also clear the engine management light by 'frigging' the system - using my mates MODUS diagnostic system.
Looking good, gotta love the V-tec
Just a quick one, why are you going threw all the hassel of using the honda box instead of just a Cossi diff. IIRC the later honda engine go the
"right" way.
Flan
Just a quick one, why are you going threw all the hassel of using the honda box instead of just a Cossi diff. IIRC the later honda engine go the "right" way.
Flan
Thanks Pete, now i know
Hehe thanks Pete - I too investigated the route of converting my Sierra LSD into a Quaife 4.1 LSD with Torsen - but it was going to cost £1300!!!
I paid £1750 for:
S2000 engine (20,000 miles FSH)
Gearbox
Clocks
ECU
Full Wiring Loom inc FuseBox
Diff
Driveshafts
It was the ratio and the fact that Matt said he could do it (get it in) that persuaded me
anyone know what power the S2000 gearbox is good for in an S2000 ??
Considering quite a few people bolt superchargers on without upgrading the diff, I would say somewhere in the region of 400bhp+. This is seems to be a
fairly common figure in the states
cheers Ricky
I owned a supercharged S2000
