Some progress BUT!
Dave Bailey - 6/9/08 at 05:58 PM
Still on target I think to get done before IVA however I had a bit of a think today and I wonder if I have made a mistake with the heater matrix pipes being a bit near the wiring panel. I know there is not much room but what do you think?
Silicon in the background is the outlet from the heater rad.
Wiring Scuttle 2
Wiring Scuttle 2
Wiring_Scuttle
Wiring_Scuttle
FIA Isolator
FIA Isolator
ST170 Engine
ST170 Engine
mackei23b - 6/9/08 at 06:04 PM
Looks OK to me, as long as nothing is directly touching the heater pipes.
Good looking build.
Ian
Humbug - 6/9/08 at 06:09 PM
If you are a bit worried you could lag the pipes with some heatshield matting stuff?
rusty nuts - 6/9/08 at 06:31 PM
Should be fine unless you have a leak. Is the back of the heater blower going to clear the dash?
[Edited on 6/9/08 by rusty nuts]
jacko - 6/9/08 at 06:41 PM
Just a warning about heater pipes some one on here had a bad accident when a pipe came off and scalded there feet and legs
Jacko
coozer - 6/9/08 at 06:54 PM
Looks OK, nice engine by the way
BenB - 6/9/08 at 07:08 PM
Personally I'd keep the heater radiator out of the scuttle. As already said a hose coming off would be seriously bad....
MK chippy - 6/9/08 at 07:56 PM
Heating! in a locost! tsssssssssss!!!
Dave Bailey - 6/9/08 at 10:30 PM
I'm afraid er in doors wouldn't go in it without a screen and heater....
I may box in the pipes and make a drain for it later.... Need to focus on getting it through SVA!
Dave B
omega0684 - 7/9/08 at 07:35 AM
how big is the TURBO?
Dave Bailey - 7/9/08 at 08:42 AM
No Turbo 'yet'! It is an ST170 engine with Dry sump and throttle bodies.
Dave B
[Edited on 7/9/08 by Dave Bailey]
